New Speedometer
Old Dec 29, 2018 | 08:36 AM
shumanfoo's Avatar
Default New Speedometer
Hi,
I need to replace the speedometer on my 1996 Accord LX 2.2. I’ve been checking on EBay for one. Confusing. Sometimes it says only good if no ABS. Sometimes it says your mechanic must adjust it once installed. Not sure if I have ABS and what does my mechanic have to adjust?
Thanks for any help.
Old Dec 29, 2018 | 09:10 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: New Speedometer
You can just replace the speedometer circuit board. That way, you retain your original odometer reading. ABS is not relevant. No adjustment necessary.
Old Dec 31, 2018 | 08:46 AM
shumanfoo's Avatar
OK. Also I can get a deal on a cluster from a manual transmission Honda. Same model, year, etc. Will that work in my automatic transmission?
Old Dec 31, 2018 | 12:30 PM
MAD_MIKE's Avatar
MM Gruppe B
MT cars do not have the AT gear selector, without it you won't have the D4 lamp to do proper diagnostics if the CEL were to come on.
Old Dec 31, 2018 | 12:45 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Yes, it should work. You're just swapping the circuit board for the speedometer.
Old Jan 1, 2019 | 10:45 AM
MAD_MIKE's Avatar
MM Gruppe B
DON"T TOUCH ANY OF THE FUEL GAUGE SCREWS!!!
One of the thin wires attaches to the plastic 'nut' on the fuel gauge, it will spin and break the wire which will make the fuel gauge read 'FULL' when it is not.
Tech-Nics
May 18, 2010 12:15 AM
theforeignkid
Nov 30, 2008 11:56 PM
umichioe
Jun 6, 2007 07:20 PM
mitch2you80
Oct 21, 2004 04:36 PM
