97 Accord No Spark
Hi, I have a 97 accord LX with a 2.2 F22B2 and I have replaced the Distributor, plugs, wires, coil, and main relay and it still only turns over. Please help. I have no vehicle to get around.
How are you troubleshooting this that it led you to believe you'd need to replace spark plugs, then wires, coil and distributor (I'd also look at the ignition module inside the distributor). Did you start troubleshooting like in these video?
You can use a multimeter to check for power at the ignition coil on it's wiring/electrical connector from ignition control module. Also at the main relay. Does the fuel pump prime with key on? Have you checked to see if there is spark from the coil output? The F22B2 uses an external ignition coil unlike the internal one on the F22B1 VTEC motor. You could also have a bad ignition control module, there are ways to test it. Another possibility is the ecu/pcm but that is unlikely.
