96 civic manual linkage issue
Old Dec 24, 2018 | 01:19 AM
Bryan Garcia's Avatar
Default 96 civic manual linkage issue
Alright. So i have a 96 civic manual. Earlier today when i was driving i tried to engage into 2nd gear but the car just didnt engage properly and it stalled(i think. The car just slowly turned off) i tried putting it into gear but it wouldnt engage even when the car was off. When the car is off I can put it into 2nd and 5th gear only but everything else has to be really forced and even when i manage to put it in 1st gear no matter how much i rev the engine it just slowly turns off. I looked online and everything points to a linkage? Idk too much about this because im still learning about cars and i hope someone here can offer some advice or a solution. If it helps i recently replaced my master and slave cylinder so i know its not those. Then about a month ago i had to replace my rack and pinion. I did detach the long shift stick under the car from the shift stick inside the car to get more room to remove the steering rack. Maybe i put it back together wrong?
Old Dec 24, 2018 | 05:44 AM
tony_2018's Avatar
Fish Twig
Default Re: 96 civic manual linkage issue
confusing
Old Dec 24, 2018 | 05:47 AM
tony_2018's Avatar
Fish Twig
Bench bleed the cmc?
Bleed the clutch system?
got back under the car to verify all the things you took apart are not loose?
Old Dec 24, 2018 | 06:29 AM
mk378's Avatar
Can you push the car in neutral with the brake off?
If two shift forks engage at once the transmission will be jammed. The mechanism that prevents two from engaging at once is inside the transmission, you would have to remove it from the car and take it apart.
Old Dec 24, 2018 | 07:48 AM
muellersfan's Avatar
As mk stated, this is a transmission issue, not a linkage or clutch issue.
Old Dec 26, 2018 | 05:10 PM
Big1000's Avatar
Is it possible that your clutch isn't fully engaging? Maybe the aftermarket slave cylinder doesn't push out as far? Do you get a grinding noise when trying to go into first?
a2s2u2
Transmission & Drivetrain
Mar 20, 2017 05:45 PM
92civeg
Apr 5, 2010 06:07 AM
jimmyfloyd182
May 7, 2007 07:41 PM
haiyter
May 3, 2007 07:08 AM
Kowalske
Honda Civic (2001 - 2005)
Dec 4, 2006 11:44 AM
