95 GSR with ITR Oil Pump
Old Nov 13, 2002 | 07:28 PM
webhitch's Avatar
Default 95 GSR with ITR Oil Pump
What Lower timing-belt cover should i use. ITR ?? Will that mate up with the GSR Upper Timing belt cover ??
Old Nov 13, 2002 | 07:41 PM
B19CivicHB's Avatar
Default Re: 95 GSR with ITR Oil Pump (webhitch)
GSR and Type R use the same oil pump
Old Nov 13, 2002 | 07:43 PM
webhitch's Avatar
Default Re: 95 GSR with ITR Oil Pump (B19CivicHB)
yes they do after 96 ... I'm just worried they changed the block or head when they changed oil pumps.
[Modified by webhitch, 4:44 AM 11/14/2002]
Old Nov 13, 2002 | 11:35 PM
kinesistech's Avatar
Use the ITR or obd2 GSR timing belt cover, I believe it fits up to the other one.
Old Nov 14, 2002 | 04:01 AM
webhitch's Avatar
Default Re: 95 GSR with ITR Oil Pump (kinesistech)
Bumpo Rama
Old Nov 14, 2002 | 07:52 AM
Katman's Avatar
Logically, it sounds like you should get yourself an ITR lower timing belt cover, it WILL mate to your GSR's upper timing belt cover..
Old Nov 14, 2002 | 08:01 AM
webhitch's Avatar
Default Re: 95 GSR with ITR Oil Pump (Katman)
Thanks man... it looks like the 96 and up GSR and Type are lower timing belt covers are the same part number.
So that is what i ordered. Thanks for everyones help... I'll try and post up if it works or not..
99teggsr
Feb 22, 2006 08:49 PM
jdmcx
Apr 30, 2004 06:39 PM
MisterB
Jan 30, 2003 03:17 PM
MisterB
Jan 24, 2003 06:37 PM
