Header for B18cR
Old Dec 22, 2018 | 12:44 PM
Junaid K's Avatar
Default Header for B18cR
Hi guys,
I've searched with very little result.
I have a 98 JDM ITR B18cR and I'm looking for a megaphone header to fit without sacrificing power.
The 'problem' is that the ITR has a full size radiator & the transmission brace is different to the b16a/b18c1,
which results in clearance issues. I bought a header & it had to be modified to fit the car. Its a direct fit for
a b16. Sits at a nasty angle under the car so I'm not happy with it.
What do you guys suggest?
Old Dec 22, 2018 | 01:05 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Header for B18cR
Personally I run the Tegiwa knock-off of the Toda 98-spec. It about 1/3 the cost of a Toda but has great build quality....especially compared to the PLM and 1320 versions. All you need to go with it is a JDM 98-spec header bracket (if you want the extra support). This style of header fits like OEM, but without the heatshielding.
https://honda-tech.com/forums/all-mo...sions-2855196/
TEGIWA EXHAUST MANIFOLD HEADER CIVIC INTEGRA B-SERIES | Tegiwa Imports
Old Dec 22, 2018 | 02:32 PM
Junaid K's Avatar
Problem is I'm looking to keep the full size radiator, my transmission brace and I want a megaphone.
Old Dec 24, 2018 | 10:22 AM
GreatWave's Avatar
10 Year Member
If you buy a header meant for a b18 you won't have clearance issues against the engine/trans brace or factory radiator/fan. Mugen, toda, spoon, 5zigen; they all fit. Buy an rmf narrow rep with the megaphone and be done with it.
Old Jan 15, 2019 | 06:41 PM
SlapSmak's Avatar
knock-offs suk
Old Jan 16, 2019 | 04:44 AM
itrdave's Avatar
Does the Tegiwa header length match USDM or JDM header length ?
Old Jan 18, 2019 | 07:10 PM
94eg!'s Avatar
#1 Super Guy
Loved
I had a PLM RMF replica and it was okay. The sound was good and the ground clearance was decent. The only problem was that you have to trim the fan shroud....and on my EG I even had to trim the tips of the fan blades and ditch the slave cylinder nipple boot.
It's JMD length with a 2.5" collector.
Old Mar 20, 2019 | 07:24 PM
wunfstgsr's Avatar
Loved
Community Favorite
1320 Toda rep with adjustable test pipe FTW best bang for your buck!
eazybmx
18
Jan 5, 2009 07:05 AM
K.Quinn
Jun 22, 2006 10:39 AM
DC2IntegraTypeR
Aug 9, 2005 09:24 PM
PeteBest
May 27, 2004 11:13 PM
Patch
40
Jan 16, 2003 09:44 PM
