304 sch10 1.5 to mild steel flange what wire to use? (manifold)
Old Dec 18, 2018 | 11:42 AM
RACEPAK's Avatar
Default 304 sch10 1.5 to mild steel flange what wire to use? (manifold)
hey guys
which rod do you guys recommend for welding 304 sch10 1.5" to mild steel flange?
iv read in some pleces that 309 is good for up to 371c ?
thanks
Old Jan 15, 2019 | 08:52 AM
para pat's Avatar
Default Re: 304 sch10 1.5 to mild steel flange what wire to use? (manifold)
309 is what you want to use.
You could use inconel 625 if you really wanted to but 309 is the right material for the job.
Old Jan 28, 2019 | 11:01 AM
AfroIntegra's Avatar
Silicon bronze would work too.
Old Feb 2, 2019 | 05:41 PM
CasperBones's Avatar
I will second the 309. I have used it before with success on exhaust. At work we use 316 and it seems to hold up well but the manifolds we weld there just flow water and are not subject to much heat.
Old Feb 2, 2019 | 07:58 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
309 all day.
mkehler
Welding / Fabrication
Jul 9, 2009 09:48 PM
.john.
Mar 4, 2008 06:52 AM
AH1078
Feb 10, 2007 01:35 PM
bunnyrabbit
Sep 14, 2005 09:39 AM
