Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
A/C belt makes awful sqeal noise when on
Old Dec 14, 2018 | 09:11 AM
Andrew Townsley's Avatar
Default A/C belt makes awful sqeal noise when on
So I have a 2001 ex coupe and since winter hit, my car began to have a crazy squealing noise when I have my heater/ a/c on. It goes away when I get up to like 25mph or I turn my heater off. I've been reading and saw you can adjust the alternator belt. Would this be my solution?
Old Dec 14, 2018 | 10:11 AM
Chrisfrom1986's Avatar
Default Re: A/C belt makes awful sqeal noise when on
The only noise the heater could possibly make is from the fan blower, unless you have the a/c on which is just stupid. Check the belt condition, tension, tensioner bearing and finally the compressor bearing.
Old Dec 14, 2018 | 11:04 AM
What's weird though, is when it isn't making the noise and I turn on my rear defrost, it kicks the sqeal back on. Still the same thing?
Old Dec 14, 2018 | 12:03 PM
Check all your accessory belts for condition and proper tension.
Old Dec 17, 2018 | 01:16 AM
Polis_Ranger's Avatar
Hi there! I am having sort of the same issue. Belt would squeal something awful when I would turn my A/C or the defroster on. My battery light would also come on and the car felt like it wanted to die. I replaced the belt and now when I turn the A/C or defroster on, I get a much more rough noise. No more squealing, but it seems to me like the A/C compressor bearing might be going out?
Old Dec 17, 2018 | 05:50 AM
NDNV's Avatar
A/C is generally installed for the purpose of cooling, but a by product of cooling air is the condensation of water vapour, therefore an air conditioner will dehumidify and I use mine for that purpose through the winter. It's also good for the air conditioner to be used from time to time during the months when you wouldn't use it for cooling to keep the seals lubricated.
Azavala
May 19, 2015 06:12 PM
Liquidice944
May 20, 2013 07:29 AM
GSRpoweredSI
Jun 20, 2007 01:13 PM
frosted
Jul 2, 2005 06:36 AM
ludetuner
Oct 28, 2004 05:46 PM
