96 Honda civic ek h22a swap injectors not firing
Ok so I swapped a h22a into my 96 EK at first it would just crank and didn’t have spark. I switched out the ign coil thought it would start. Then I realized that my injectors weren’t firing. I checked everything 12v, switched harness, switched injectors, switched main relay, checked all fuses, all grounds are connected, tried different ecu’s. I just dont know what could be the problem at this point
NorthWest94Teg
Feb 13, 2004 02:53 AM
