95 EX Coupe Dash Light Wiring Diagram
I am looking for the wiring diagram for the instrument cluster and dash lights for my 95 EX Coupe... the dash lights were working but randomly cutting off and would turn on if I smacked the dash. Now they just don't come on at all. Any help would be appreciated.
Check that the tail lights are working, the dash lights come from the same switch and fuse. If tail lights work but dash lights cut on and off, it is usually the dimmer control. Pry the control out of the dash and unplug it. Jump the solid red wire in the plug to the solid black one. Turn the light switch on and the dash lights should come on fully bright. If that works, replace the dimmer control.
I sincerely doubt that every bulb went bad at the same time.
I will try that thank you.
Haven't looked at the back of an EG cluster in a long time, but I know that on EF's the bulbs connect to a flexible circuit board on the back of the cluster - the 'springiness' of the little copper connectors wear out, and the connection gets loose. I'm constantly having a light in my cluster either on or off...it's a good day (or night?) when they're all on.
DanGAvery
Nov 30, 2018 04:35 PM
bambam530
Oct 27, 2013 07:12 PM
