1994 Civic Hatch Fuel Problem
Old Dec 11, 2018 | 09:15 PM
SR-Vtech's Avatar
Icon5 1994 Civic Hatch Fuel Problem
So, after having somebody cut the ends off my fuel pump, i have now gone and replaced the fuel pump assembly and pump. When i turn the key the pump kicks in, and i can feel it filling the line with pressure but nothing reaches the engine side.
I pulled the fuel filter & hose from it and there was 0 pressure. the line that runs from the fuel pump to underneath the fuel filter i can force air from engine side --> Fuel pump side. But when I try to force air from Pump side --> engine side, its blocked.. Nothing comes through.
So my problem isnt that the line is clogged because i can blow backwards into it and it shoots gas all over the rear hatch. This problems isn't letting fuel reach the front, the pump just primes and eventually sounds like **** because theirs too much pressure.. any ideas?
Front of car Fuel Pump Hose
Air will flow this way
But not this way
Old Dec 12, 2018 | 02:29 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: 1994 Civic Hatch Fuel Problem
You replaced it with a new or used pump? May just be a bad unit.
Old Dec 12, 2018 | 08:02 AM
muellersfan's Avatar
Replace the obstructed fuel line.
Old Dec 12, 2018 | 09:04 AM
SR-Vtech's Avatar
New fuel pump, I even used the one from my other car ( walbro 255LPH ). If its obstructed how come air freely flows one direction and not the other?
Old Dec 12, 2018 | 09:16 AM
The foreign obstruction is by chance positioned to act like a check valve. Replace the fuel line or continue trying to dislodge the obstruction with compressed air.
Old Dec 12, 2018 | 07:34 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
I agree with muellersfan... do this ^^^^^^^^^ !!!!!
Undergroundeg6
Jul 19, 2013 01:23 PM
cleo7
Jan 23, 2013 08:53 AM
SlowSlammedSedan
Jan 10, 2009 06:50 PM
ultrablackhatch
Jul 21, 2006 05:43 PM
Z6REX-SI
10
Mar 9, 2004 07:50 AM
