still trying to figure out why wipers work on their own
Old Dec 10, 2018 | 10:05 PM
Steve Clifford's Avatar
Default still trying to figure out why wipers work on their own
Hello. Hopefully I am narrowing down why my wipers work by themselves on my 93 accord. Today I turned the headlights on on a nice sunny day and the wipers came on as well right away. After about 15 secs I turned the lights off and the wipers went to park. So where is the link between lights & wipers. I'm reading info there may be a bad earth, but no idea where to start to look.
Old Dec 11, 2018 | 06:13 AM
ColeCooper90's Avatar
Default Re: still trying to figure out why wipers work on their own
It looks like there are 2 grounds in the dash, one below and to the left of the steering wheel, and another around the glove box. I would start there. Hopefully it's a ground problem and not a shorted wire.
Old Dec 11, 2018 | 10:12 AM
thanks for the reply. Forgot to mention. My accord is a right hand drive. Are the earths in the same position?
Old Dec 11, 2018 | 10:30 AM
I would imagine theyre probably the same, or close. Honda usually keeps their grounds reatively easy to find. Look for some brass bolts with a bunch of wires going to them.
Old Dec 11, 2018 | 10:18 PM
Hello. Thanks for the tip. I spent an hour looking up under the dash. I pulled the headlight/wiper shrouds off, looked around the glove box and I couldn't see any earth wires there, just lots of of normal connector plugs, noting near the steering wheel either
Old Dec 13, 2018 | 05:48 PM
schreps's Avatar
try looking behind the passenger kick panel (or maybe on drivers side on uk vehicles) near the fuse box.
https://www.hondaautomotiveparts.com...--wire-harness
item 25 are the ground bolts, not a great drawing but gives the general location.
Old Dec 15, 2018 | 02:11 AM
Hello. I did manage to find 2 black ground wires behind the kick panel directly under the fuses next to the accelerator, but they looked quite ok. I decided to call a Honda wrecker to ask his opinion. he said it could possibly be a short in the wiper/headlight assembly under the steering wheel. If that's the case it's worth a try. do you know from what year models will fit my 93 Accord?
Old Dec 15, 2018 | 04:15 PM
schreps's Avatar
35255-SM5-A01 lights 90 to 95
35256-SM4-G81 wiper 92 to 00
above is from ebay for aftermarket
Old Dec 16, 2018 | 01:37 AM
Thanks for the info. Are these parts interchangeable to right hand drive?
Old Dec 16, 2018 | 10:43 AM
schreps's Avatar
give your local honda dealer a ring. I tried a couple of websites for sydney dealers but no online parts diagrams. I think they want you to come in for a pint. cheers mate.
HondaAcc94
Oct 29, 2014 10:18 AM
dresslkr
Apr 29, 2012 06:11 AM
templarvisonz
Jan 10, 2009 11:00 AM
aerc07
Apr 7, 2008 02:08 PM
87lxi
Sep 10, 2004 11:39 AM
