'06 V6 Accord misfiring all cylinders
Cannot see the picture you posted here at work; I guess the firewall is blocking it...
Have you checked your coils? Per the OBD-II interface, my 2001 suddenly started "misfiring on all cylinders", however, upon further analysis it was a single coil.
I don't know how to test the coils. I'll have to look into that. I'm getting the errors P0102 (MAF related), P0300, P0301, P0302, P0303, P0304, P0305 and P0306. That's what the image shows.
Simple, unplug one and see if the engine starts running worse; if it does, then that coil is good and move on to the next one. Odds are pretty good you'll encounter a single coil where nothing happens when you unplug it, and when you do, replace that one.
LSegHatchy
Apr 10, 2005 09:19 PM
