F22b swap to f23a dizzy help
Old Dec 10, 2018 | 08:09 AM
A1Premium's Avatar
Default F22b swap to f23a dizzy help
i swapped all the engine components from my f22 to the f23 like the alt, dizzy, power steering, intake I’ve never had any code before but now woth the swap I’m getting a P1381 which is cylinder position i need help finding the problem I’ve baight like 2 distributors but none of them will start my car for some reason only the old one will
Old Dec 10, 2018 | 02:23 PM
schreps's Avatar
Default Re: F22b swap to f23a dizzy help
There were two distributors for 96-97 accords, the TEC Distributor Assembly (Td-76U), 30100-P0B-A01 and Hitachi (dont know the honda part number). It might matter which one the ECU prefers... both types are available on ebay.
https://www.ebay.com/itm/New-Ignition-Distributor-for-96-97-1996-1997-Honda-Accord-EX-2-2L-F22B1-Hitachi/221142349020?fits=Year%3A1997%7CModel%3AAccord&has h=item337d1c74dc:g:ehoAAMXQn11Re3tk:rk:3:pf:0
https://www.ebay.com/itm/NEW-Ignition-Distributor-for-96-97-Honda-Accord-Prelude-2-2L-SOHC-TD-76U-TD76U/401200252929?fits=Year%3A1997%7CModel%3AAccord&has h=item5d69660801:g:Am8AAOSwN2VZPCMR:rk:2:pf:0
I dont know if the distributor can be installed 180 degrees out of phase but you should check. since the connectors look different I assume you got the correct one. In the past I have had issues on a 91 with chinese made igniters. if no spark, I suggest getting a Japanese igniter, they're not cheap so I pull used ones from pickapart.
Old Dec 10, 2018 | 09:56 PM
A1Premium's Avatar
How do i know if my car is tec or hitachi? But sounds like it almost will turn on but i won’t. itll crank forever
Old Dec 10, 2018 | 09:59 PM
A1Premium's Avatar
Ahhh yeah so mine uses tec i can see by the connectors. But i don’t know what to do now
Old Dec 13, 2018 | 05:54 PM
schreps's Avatar
plugged in correctly? do you have spark? you remembered to install the rotor?
Old Dec 13, 2018 | 09:07 PM
A1Premium's Avatar
it sounds like it wants to start up but it doesn’t, everything is wired up right and yes i put the rotor on
Old Dec 14, 2018 | 03:33 AM
schreps's Avatar
assuming spark is good, could be:
1) spark plug wires are out of order
2) the distributor shaft is turned 180 degrees
3) its not a spark issue, the injectors are not supplying fuel, try spraying starting fluid into the intake while cranking to see if it will run
4) double check the grounds on the engine. When you put the f23 in I assume you used the f22 harness. Check that the distributor housing is grounded well thru to the battery.
Old Dec 17, 2018 | 08:56 PM
A1Premium's Avatar
i i found out that when the car is cold the code turns on but when the car is at normal temp with the code cleared the code will not come on at all I’ve let the car on for a long time the code will not com back
Old Dec 21, 2018 | 03:22 PM
schreps's Avatar
you got it running???
Old Dec 21, 2018 | 05:32 PM
A1Premium's Avatar
It runs just with the old dizzy
Old Dec 22, 2018 | 11:17 AM
schreps's Avatar
You have an issue with fleabay distributors. buy a good used OEM distributor from a car exactly like yours.
thewhocrew
11
Aug 22, 2008 08:12 PM
crxSoldado
Apr 12, 2004 04:57 PM
joesefcivic
Jul 15, 2003 04:03 PM
