Power Steering Pump Issue
Old Dec 10, 2018 | 05:05 AM
MikeFeuti's Avatar
Default Power Steering Pump Issue
I'm building a 93 Del Sol for my daughters friend and I need to keep the power steering. The Del Sol was just a shell when I bought it so I don't have the power steering pump from it.
I've placed a d16y8 engine from a 98 civic ex in the car and of course the power steering line from the del sol will not fit on the power steering pump from the d16y8. What are my options for keeping the power steering?
Thank you
Old Dec 10, 2018 | 09:55 AM
muellersfan's Avatar
Default Re: Power Steering Pump Issue
92-95 Civic pump?
Old Dec 10, 2018 | 10:02 AM
MikeFeuti's Avatar
The power steering pump I have in hand is from a 99 civic EX. The high pressure hose on the car does not fit, it is the stock line on the 93 del sol. Other than somehow changing the line how can I make this work? It doesn't look like the bracket for a 93 pump will mount up to the d16y8 but I could be wrong. I would prefer to not have to change the line in the Del Sol. I know the 99 pump will not work with the current line.
Thank you
Old Dec 11, 2018 | 06:15 AM
MikeFeuti's Avatar
anyone?
Old Dec 11, 2018 | 06:38 AM
mk378's Avatar
If you can get the pump mounted, get a hose from a 98 and have a hose shop take the pump end off and make a custom adapter hose for you (98 pump to 93 rack).
If you can't get the pump mounted it would be ahead forget using that 98 pump and source one that fits the 93 engine mounts. The tapped holes in the block and head are the same for any D series engine, but the mount pieces that attach the engine to the car are different.
Old Dec 11, 2018 | 07:26 AM
94 Civic Si's Avatar
Premium Member
Loved
Community Favorite
Originally Posted by muellersfan
92-95 Civic pump?
^^^ This...
Old Dec 11, 2018 | 08:12 AM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Yes, find a '92-95 Civic P/S pump... your life will be much easier than trying to make a '96-00 pump work.
Old Dec 17, 2018 | 04:03 AM
MikeFeuti's Avatar
Thank you all. I'm going to see how much it will cost to have the hose made. There is a shop near me that does t his. If it is crazy expensive I'll source a 92-95 pump.
Old Dec 18, 2018 | 10:18 AM
LiteraCola's Avatar
Corvette Forum Member
Can't beat this... Or hit a junk yard for a non-leaky one. Also, they're very simple to rebuild if you find a leaky one.
ys1civicsi
14
Aug 23, 2018 09:03 AM
Curlybandit
Nov 6, 2017 08:18 AM
89redrex
Northeast (Sales)
Apr 11, 2013 07:32 AM
CopperSol
Jan 19, 2006 12:51 PM
StreetProjectz
Mar 29, 2004 07:17 PM
