RPMs dont showing
Old Dec 7, 2018 | 12:59 PM
Sqni's Avatar
Default RPMs don't showing FIXED
Hi
I have problem with my tachometer. It don't showing rpms. Problem probably cause bad distributor because my tachometer worked before B18 swap (I have EJ6). On the original (MB6 civic) rpms did not showing too. It can be bad distributor sensor or something that ? And how can I fix it ? )
Thanks
Old Dec 7, 2018 | 01:14 PM
tony_2018's Avatar
Fish Twig
Default Re: RPMs dont showing
pics of cluster?
Old Dec 7, 2018 | 01:20 PM
Sqni's Avatar
Originally Posted by tony_2018
pics of cluster?
Screenshoot from some video from my mobile
Old Dec 7, 2018 | 02:08 PM
Sqni's Avatar
pics of cluster?
Sure.
https://drive.google.com/file/d/11Uv...ew?usp=sharing
Old Dec 7, 2018 | 07:54 PM
tony_2018's Avatar
Fish Twig
Originally Posted by Sqni
Hi
I have problem with my tachometer. It dont showing rpms. Problem probably cause bad distributor because my tachometer worked before B18 swap (I have EJ6). On the original (MB6 civic) rpms did not showing too. It can be bad distributor sensor or something that ? And how can I fix it ? )
Thanks
leads to bad wiring. ther to start
Old Dec 7, 2018 | 10:55 PM
triple beam's Avatar
10 Year Member
sometimes it could be a bad rpm guage.... you can also try testing your instrument cluster on another stock ek civic
Old Dec 7, 2018 | 11:09 PM
Sqni's Avatar
I don't think that it's a bad wiring because swap was made by man who did a lot of swaps. And my cluster worked fine before swap. And I wrote that the on the original MB6 civic rpms don't showing too. I have EJ6.
Maybe today I going to check wiring. Can it be a bad ignition control module? I can swap it from my old motor.
Old Dec 8, 2018 | 01:54 AM
Sqni's Avatar
Ok guys tachometer is working. I just swapped ICM module from my old motor to new one. Thx everyone for replies...
enot767
Oct 10, 2008 01:18 PM
ILuvMyJdmDc4
Nov 27, 2007 04:43 AM
mini-v-si
Mar 17, 2004 06:29 AM
toooslow
May 31, 2003 08:49 PM
sicivic
Jun 13, 2002 06:54 PM
