96 accord sedan 2.7l FRONT hub assembly
Old Dec 2, 2018 | 11:20 AM
Shaun Heim's Avatar
Default 96 accord sedan 2.7l FRONT hub assembly
I have a 96 honda accord sedan 2.7l trying to find a front hub assembly and all I can find is the rear
Old Dec 3, 2018 | 06:02 AM
hondamark35's Avatar
Default Re: 96 accord sedan 2.7l FRONT hub assembly
you're in need of the whole assembly or just a replacement bearing? the bearing is available separately.
Old Dec 3, 2018 | 07:28 AM
Shaun Heim's Avatar
whole assembly
Old Dec 3, 2018 | 11:59 AM
ColeCooper90's Avatar
Rockauto.com
Old Dec 4, 2018 | 04:44 AM
Originally Posted by ColeCooper90
Rockauto.com
not for the V6, front "whole assembly". appears only the bearing is available
Old Dec 4, 2018 | 04:44 PM
Old Dec 4, 2018 | 04:46 PM
Only one opyion, but at least it's an ac delco rather than some random off brand.
Old Dec 4, 2018 | 09:16 PM
MAD_MIKE's Avatar
MM Gruppe B
AC Delco 'Advantage' is not their top of the line.
Stick with Timken or National.
95-97 Sedan V6 and 95-97 Odyssey use the same front wheel bearing.
Hubs for the V6 are a bit unique, they look like the 4 banger stuff but has a larger outer bore.
Unless there is something completely wrong with the original front hubs, just reuse them and install a new bearing. Besides the yarde the only other place I think has the V6 hubs would be Honda.
Racemag
Mar 3, 2010 06:04 PM
bdmlilburn
Mar 31, 2009 03:28 AM
B18C_EJ8
Jan 11, 2008 06:47 PM
bigislandc2
May 20, 2007 09:45 AM
vtecCJ
Jan 9, 2004 06:16 PM
