Civic Si 2000 max revs at 7k rpm
Hook up a code reader that shows live data to see whether the tach is reporting the correct engine rpms.
Fuel cut-off action also takes place when engine speed exceeds 6,900 rpm (D16Y5, D16Y7 engine; D16Y8 engine: 7,000 rpm, B16A2 engine: 8,100 rpm), regardless of the position of the throttle valve, to protect the engine from over-revving. With '99 D16Y7 engine (A/T) and '99 D16Y8 engine (A/T), the PCM cuts the fuel at engine speeds over 5,000 rpm when the vehicle is not moving.
darkcivic90
Jul 21, 2012 02:37 PM
piku303
Jun 14, 2012 01:38 AM
Mfoehrkolb
42
Jul 23, 2008 07:11 PM
