Pics for archive: Stock OEM plug-Stock plugs with 60k
Old Nov 13, 2002 | 06:08 PM
SonicGSR's Avatar
Default Pics for archive: Stock OEM plug-Stock plugs with 60k
I know the plugs tell you alot about how a motor is running:
Need some expertise advise on how these things look
Thank you.
60k plugs: To me they just a bit of carbon on them, I could probably run them longer but since im doing a valve adjustment I thought id change them
Stock plug: How pretty
Old Nov 13, 2002 | 06:25 PM
Tomakit's Avatar
Default Re: Pics for archive: Stock OEM plug-Stock plugs with 60k (SonicGSR)
See how the electrode, or whatever the hell it is, is rounded? That means your plugs are *very* worn. The color of them looks fine, just a little rich = good.
Tom
Old Nov 13, 2002 | 06:29 PM
SIK IN DA HED's Avatar
New User
i wouldnt even run them for more than 5,000 on my car.
Old Nov 13, 2002 | 06:33 PM
Tomakit's Avatar
Default Re: Pics for archive: Stock OEM plug-Stock plugs with 60k (dlplayboy)
When I was turbo I was changing my plugs at every oil change, lol.
Old Nov 13, 2002 | 06:42 PM
SonicGSR's Avatar
Default Re: Pics for archive: Stock OEM plug-Stock plugs with 60k (Tomakit)
Wow!
Old Nov 13, 2002 | 08:08 PM
araknis's Avatar
New User
I thought stock GS-R plugs were the NGK Platinums.. I noticed yours said Denso..
Old Nov 13, 2002 | 09:00 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Pics for archive: Stock OEM plug-Stock plugs with 60k (araknis)
Maybe Denso Iridiums $$$$$$$
I run NGK copper plugs and change them about every 4th oil change.
Old Nov 13, 2002 | 09:26 PM
SonicGSR's Avatar
Default Re: Pics for archive: Stock OEM plug-Stock plugs with 60k (PatrickGSR94)
Denso #PK20PR-L13
Can someone tell me if these are platinums?
Dealer sold me these, asked which Integra model it was etc
Hope they are the right ones
Old Nov 14, 2002 | 03:45 AM
Pineapple Devil's Avatar
ngk and denso are the same company. like honda acura
Old Nov 14, 2002 | 07:51 AM
IntEGNYC's Avatar
Default Re: Pics for archive: Stock OEM plug-Stock plugs with 60k (Pineapple Devil)
On an Integra LS, how often are you supposed to change your Spark Plugs?
Old Nov 14, 2002 | 08:34 AM
BSQ's Avatar
BSQ
The electrode is fine (ie. not worn --> rounded). This is the shape of the electode on a platinum plug (eg. see the shape of the electrode of the new plug). Now if the plug was a copper plug, it would be considered worn.
BTW, you can go to http://www.ngksparkplugs.com/techinf...q/faqread2.asp for some very informative information (with picture ) which shows how to "read" a spark plug.
Old Nov 14, 2002 | 08:36 AM
BSQ's Avatar
BSQ
Acura uses NGK and Denso plugs as OE plugs. My '94 GS-R came with Denso platinum plugs.
Old Nov 14, 2002 | 08:41 AM
BSQ's Avatar
BSQ
Denso #PK20PR-L13
Yes, they are platinum and they are equivalent to the NGK PFR6G-13. Look at the stick on the undeside of your hood. It should show you the NGK and Denso spark plug part number for your car.
Old Nov 14, 2002 | 08:42 AM
MyVtec8u's Avatar
as long as they aren't running white don't worry about it!!!
Old Nov 14, 2002 | 08:46 AM
SonicGSR's Avatar
Default Re: Pics for archive: Stock OEM plug-Stock plugs with 60k (MyVtech8u)
Good deal thx
Old Nov 14, 2002 | 08:49 AM
BSQ's Avatar
BSQ
Not true. They are two seperate companies.
Old Nov 14, 2002 | 08:52 AM
BSQ's Avatar
BSQ
Default Re: Pics for archive: Stock OEM plug-Stock plugs with 60k (IntEGNYC)
The RS/LS/GS/SE use copper plugs and the service manual states that they should be replaced every 30,000 miles. They GS-R/Type-R use platinum plugs and they should be replaced every 60,000 miles.
Old Nov 14, 2002 | 08:53 AM
SonicGSR's Avatar
Default Re: Pics for archive: Stock OEM plug-Stock plugs with 60k (BSQ)
BSQ: They look a little dirty how much longer will they hold up?
Old Nov 14, 2002 | 09:08 AM
BSQ's Avatar
BSQ
It's hard to say how much longer they will last. If they have 60K miles on them, I would replace them.
sp00led
Jun 10, 2004 08:45 PM
Snafu-Si
Jun 6, 2003 01:51 AM
HX_Guy
Oct 23, 2001 08:19 PM
sporter
Jun 28, 2001 07:41 PM
Babalouie
Jun 24, 2001 07:33 PM
