2001 accord taillight that is on the rear hood
Old Nov 27, 2018 | 12:41 PM
thanks 4 help!'s Avatar
Default 2001 accord taillight that is on the rear hood
I fixed it! Praise the Lord! It just came out of the socket! I used a screwdiver without the driver in the handle and the handl.e without a diver in it, fit the part perfectly to unscrew the bolt! then...I when I removed the plug for the light, the bulb stayed in the unit because it was out of the socket. So I just had to put the bulb back into the socket and it all works now!! Glory! Thank you for reading this, but it's fixed. wohhhooo! God is good!
(It's the BRAKE LAMP on the trunk hood) When I open the trunk the BRAKE lamp light (on the trunk hood) that is out, has a plastic covering (dome) on it and it appears to be tightened down so it doesn't just snap off. Is there any video to see how to change this bulb that is inside? I cannot find anything dealing with this light bulb. Thank you!
Last edited by thanks 4 help!; Nov 27, 2018 at 01:31 PM. Reason: I fixed it! Praise the Lord! It just came out of the socket!
Wheelman323
Paint and Body
Feb 4, 2010 02:18 PM
dustin2001
Jan 28, 2008 10:09 AM
SJcivic
Welding / Fabrication
Aug 28, 2006 11:02 PM
KMk51188
Feb 13, 2006 05:22 AM
Captain Flaps
Jan 12, 2006 07:14 PM
