Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Automatic Transmission Oil Pressure Switch
Old Nov 27, 2018 | 09:41 AM
joenobodyyet's Avatar
10 Year Member
Default Automatic Transmission Oil Pressure Switch
My car (2008 Civic LX automatic 4 door, 75,000 miles) starting shifting weird a few weeks ago and the green light next do D(drive) started flashing, then my check engine light came on. I got codes P0847 and P0756. After about a week, the check engine light went off, and it seems to be shifting better again. I have read MANY posts online about this common problem and most say that it's most likely a bad transmission pressure switch sensor. I figured I would buy one and swap it out, but I am not sure exactly which transmission fluid pressure switch to get. Here are the 3 options I have seen in posts:
28600-RPC-013
28600-RPC-003
28600-RPC-004
I was sent this: "The 3rd Clutch Transmission Fluid Pressure Switch is Honda part # 28600-RPC-013 which replaced part # 28600-RPC-003.
The washer/gasket part # is 90471-PW7-A00. The switch is located at the bottom of the transmission housing."
So I went on eBay and bought a genuine Honda switch part 28600-RPC-013, but the person sent me 28600-RPC-004. I was under the impression that the -004 was for the 2nd gear/clutch transmission fluid pressure switch and the -013 (which replaced -003) was the 3rd gear/clutch transmission fluid pressure switch.
The guy on eBay says that the 28600-RPC-004 is the replacement part for 28600-RPC-013. Can anyone help and confirm if this is true or not? I would rather not take a gamble with the wrong part. Thanks
Old Nov 27, 2018 | 12:09 PM
m_shake's Avatar
Default Re: Automatic Transmission Oil Pressure Switch
28600-RPC-004 is the part number for the 3rd clutch pressure switch
Old Nov 27, 2018 | 06:29 PM
10 Year Member
Thanks, what are 28600-RPC-013/28600-RPC-003 used for?
Is 28600-RPC-004 what I need? I most likely need to replace the switch at the bottom of the transmission housing?
My error codes were:
P0847: 3rd Clutch Transmission Fluid Pressure Switch Circuit Short or Stuck ON
P0756: Shift Solenoid "B" Stuck Off
Thanks!
Old Nov 28, 2018 | 09:25 AM
m_shake's Avatar
28600-RPC-013 Was for 2nd clutch originally but supersedes to a 28600-RPC-004.
Old Nov 30, 2018 | 05:12 PM
10 Year Member
Thanks for the help. I spoke to a guy at the dealership (although I try to avoid dealership prices) and he told me that they are using the -004 for both (2nd and 3rd) switches now. So I installed the -004 switch yesterday and so far so good, although the check engine light hasn't been staying on for too long. Hopefully it doesn't come back though.
joenobodyyet
Jul 13, 2024 07:35 AM
rdemel
Honda Civic (2001 - 2005)
Aug 1, 2011 11:22 AM
monkey_man07
Aug 16, 2007 07:17 PM
