B18C rebuilt on EG9 suggestions?
Old Nov 26, 2018 | 10:18 PM
Brembomaster's Avatar
Default B18C rebuilt on EG9 suggestions?
Hello all,
I am planning to rebuild the B18C on my Eg9 because that is a high oil consumption. and my buy list as below, could you guys give me some suggestion?
Reface the cylinder head with stock cams and replace the valve stem.
Replaced 81mm YCP high compression piston and piston.
ACL small end rod bearing. (to retain the crankshaft main bearing)
Otherwise, how to choose the size of the rod bearing, I know almost are the STD size , is that fit for almost crankshaft as well? Or I need to match the code on the shaft should be better?
Thanks all of you.
Old Nov 26, 2018 | 11:18 PM
Gianlukito's Avatar
Default Re: B18C rebuilt on EG9
Originally Posted by Brembomaster
Hello all,
yes, take the oem bushings finding the right size by matching the letters on the block with the numbers on the crankshaft.
Old Nov 26, 2018 | 11:30 PM
Thanks you for replay.
Whats the issue if use the ACL STD bearings? many ppl use the STD for their track car.
Old Nov 27, 2018 | 06:02 AM
ross2004's Avatar
Measure, don't guess or assume.
Old Nov 27, 2018 | 01:41 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
If your engine is consuming oil I would go with 81.5mm pistons and have it bored to fit the pistons. I've seen allot of people rebuild engines standard bore only for it to continue burning oil because the cylinders are out of round.
Old Nov 27, 2018 | 03:41 PM
Yes, Thanks you for suggestion.
I have to measure the cylinder wall firstly then to decide what diameter piston to use.
May I know what process I have to do if go for the 81.5mm piston.
Old Nov 28, 2018 | 05:59 PM
iwannarace's Avatar
Just take it to a machine shop and ask them to bore it out .5mm. Pretty basic and relatively inexpensive. I remember paying around $300 for a head milling, .5mm boring and a rotating assembly balancing. If you bring it to them disassembled it should be less expensive.
Old Nov 28, 2018 | 06:14 PM
Do it need bore the clearance for the piston ring thermal expansion?
Old Nov 28, 2018 | 07:43 PM
iwannarace's Avatar
Just let the machine shop know what size pistons and what material they're made of. If the machine shop is worth their salt, they'll bore it the right amount, no problem.
Old Nov 28, 2018 | 08:48 PM
Loved
Community Favorite
It's best to bring them the block and new pistons and tell them what size p2w clearance you want. For my all motor b20 I went .002" p2w for my turbo b20 it's .004" p2w.
Old Nov 29, 2018 | 04:29 AM
Chance EG's Avatar
At the very least use plastigauge.
I also agree that boring out to 81.25 or 81.5mm would be worthwhile, just to get a completely fresh surface on the cylinders (obviously with a fresh hone too) and get a perfect circle. Cylinders oval out over time/mileage.
Old Nov 29, 2018 | 05:26 PM
Default Re: B18C rebuilt on EG9 suggestions?
otherwise, anybody tried use by "YOKANA" gasket kit? I found it from ebay that is cheaper, I want to try it and the head gasket use by OEM one.
raverx3m
Dec 17, 2015 12:08 PM
JDM_EK_JOE
37
Aug 6, 2006 06:41 AM
jdmEFsedan
25
Jan 29, 2005 05:36 PM
waxbunny
Oct 14, 2004 07:51 PM
Aeka GSR
Sep 25, 2003 07:25 PM
