Auto transmission rebuilt but won't get in gear
So I just rebuilt the transmission in my 94 del sol, I believe it's an S24A tranny. It's all back together installed, everything is hooked up, but the car won't go into gear. I can move the shifter through all the gears while in the car, but nothing in the tranny seems to engage and the car won't move. Does the torque converter buddy need to build up pressure since I just refilled the trannny with fluid, or I'd the something else that could be causing this issue. In addition I have multiple codes on now, where as before, I had none. Prior to taking it apart the vehicle would only shift at 5k rpms, and only once I got it high enough and then let off the gas. Send your expert thoughts please.
Just so you know, the pump of the automatic transmission is in the torque converter, no fluid prevents the pump from priming and then you have no fluid flow through the transmission. This in turn prevents any of the valve bodies and pressure valves from operating, which in turn means, doesn't shift gears.
I do not know if running the car without fluid in the torque converter causes damage. At the bare minimum, it means dropping the tranny to fix the problem.
oh lord...bro please do some research next time before you start on a project like this. refilling the torque converter is a must. Now you gotta take everything apart again just to get to the torque converter.
I had to do a drain and fill on my little sis 05 crv. Had a shudder for some reason and when I check the fluids that **** was filled passed the line, was ****** pissed and found out my damn old man did that ****. Ever since I filled it up properly it hasn't had that shudder at all. CHRIST ALMIGHTY the **** I gotta fix ever since coming back to New Orleans.
Yeah that sucks, live and learn. Bought it not running and rebuilt the engine and the trans. Sucks but I'll probably just have to keep figuring it out, and drop the trans
So I dropped the tranny and pulled the torque converter and it had filled since being run. The car still doesn't move in any gear, looking for any advice in what would cause this. Thur car will also not rev about 2500 rpms. No it's what to do from here.
I would've topped off the converter, stuck it back it, lift and bolt the transmission up, bolt the converter to the flex plate, install axles, install wheels, put car on all 4 wheels, warm up car, shift through all gears, turn off car, check fluid level.
You killed your rebuilt transmission.
Yeah dude it was full, completely full. Not sure why you would doubt it. There's no benefit to making things up on here when one is looking for answers. Besides the problem wasn't the Torque converter
Maybe. I found another tranny, transferred some of the parts off of my old one and put them on the one I bought. it runs and moves now. Still shifts at high RPMs, but is a very smooth shift. I'm wondering if someone had the ECU flashed at some point. Since the car is a 94 and the ECU has 95 civic written on it in red marker. Possible a previous owner bought it separate.
As for flashing the ECU, if it's not chipped, it's highly unlikely as it would take the 900 USD HIM unit and another 900 USD dollar subscription to get access to the Stock OBD1 ECU settings for programming.
Also, it's my understanding the ECU's TCM only controls 4th gear and torque converter lockout. 1st through 3rd is all mechanically controlled inside the transmission.
My guess is that something was put together wrong, so the transmission was mechanically jammed. You could rev to 2500 because that's about the stall point of the torque converter.
The mechanical cable from the throttle to the transmission controls the shift points. When the driver floors the gas, the transmission will stay in lower gears to let the engine wind up to a higher rpm before shifting. If the cable is not working, it would also stay in a too low gear at light throttle, which is not good.
As noted, shifting up through 1-3 is mechanically controlled. The two solenoids on top of the transmission let the ECU decide when to engage the 4th gear and lock the torque converter, which the ECU will only do at highway speed.
the valve body has to be put back together properly, adjustments also need to be made, sonnex sells the tool you need to adjust as well as make sure your valve body doesn't get stuck. :thinkinghat:
************UPDATE************
So car is shifting properly now, turns out I need to replace the spring that connects to the throttle cable at the transmission. It was worn and not returning to the right position. As for the transmission that I rebuilt, I put something in the wrong order and chewed up my bearings. As for putting the torque converter in empty, I took my broken trans to a shop and they said that would cause zero issue and in fact that is how they install. The torque converter does turn the pump that pushes the flow of fluid through the transmission.
