Dropping Temp @ Accel
Old Nov 22, 2018 | 08:20 PM
DDY_EGC's Avatar
Default Dropping Temp @ Accel
So I change my radiator and thermostat and the upper hose in attempt to fix the problem of my temp gauge falling when I exelarate past 3500-4000 rpm and drops all the way down to the bottom line as quickly as I'm excelerating any other solutions or possibilities or what it might be?
Old Nov 23, 2018 | 02:48 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Dropping Temp @ Accel
you didn't properly bleed the coolant system
Old Nov 23, 2018 | 08:30 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Did you use a GENUINE HONDA thermostat ???
Old Nov 24, 2018 | 12:19 PM
DDY_EGC's Avatar
I went ahead and bled the system again, there were no air bubbles coming out the bleeder valve on the upper hose and I got the thermostat new from oreillys so I would hope it's a genuine Honda part my problem is still present
Old Nov 24, 2018 | 12:28 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Oreillys doesn’t sell oem Honda parts. Honda does.
Old Nov 24, 2018 | 08:48 PM
JRCivic1's Avatar
10 Year Member
Community Builder
O'Reilly's parts aren't even close to the quality of a genuine Honda part... so the fact still remains, you have a junk thermostat that will NOT close the bypass circuit when the thermostat opens. For Honda's, you should only buy spark plugs, oil and cleaning supplies at your local auto parts store. Go to the dealership for everything else.
Old Nov 26, 2018 | 07:07 PM
muellersfan's Avatar
This^
Read the service manual to learn the proper bleed procedure.
If problem persists, do diagnostic tests for a blown head gasket.
Old Nov 27, 2018 | 05:14 PM
tony_2018's Avatar
Fish Twig
you didn't bother to drive to honda for a thermostat
you didn't bother to bleed the air system until after someone told you to
you didn't bother to care for your ride
you don't deserve it.
Alexnlisa
Honda Civic (2001 - 2005)
Apr 9, 2018 01:24 PM
Mitsuoko
Honda Civic (2006 - 2015)
Dec 15, 2016 10:03 PM
mike.lamka
Jan 16, 2014 06:58 AM
Rylan
22
Mar 15, 2011 12:40 PM
