Suspension & Brakes Theory, alignment, spring rates....
Eibach springs not level at the top = top hats lopsided!
Old Nov 22, 2018 | 05:52 AM
mikzsan's Avatar
Default Eibach springs not level at the top = top hats lopsided!
Hi I ordered a Bilstein B12 for a cl9/tsx 04.
I have noticed the Eibach springs supplied are not level at the top, whereas the OEM springs are. (see pics attached).
When screwing on the top hats (oem ) , they start to become lopsided. Haven't yet installed in the car yet, so unsure if loaded weight will make a diff, but can't see how.
There is no groove under the oem top hat to correct this. They are relatively flat underneath.
Has anyone had springs like this and had to use OE top hats? Any issues?
Advice is greatly appreciated.
Old Nov 22, 2018 | 02:12 PM
Tyson's Avatar
Default Re: Eibach springs not level at the top = top hats lopsided!
Seems fine to me.
Did you get front and back springs correct?
Old Nov 22, 2018 | 02:54 PM
mikzsan's Avatar
Yes
Old Nov 23, 2018 | 09:34 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
OEM springs aren't flat topped.
The eibach uses dead coils up top.
They will compress more than the OEM live coils. Once bolted down, and/or with the car's weight, they should become the same pigtail shape as OEM.
You're fine.
Old Nov 26, 2018 | 04:21 AM
mikzsan's Avatar
You're fine.
Thanks. So once they become the same shape as OEM after installed, they will automatically sit flatter against the top hat ?
ie any forces that are holding the top hat slanted are overcome or corrected after install , or am I required to undo the top nut once shocks installed, then re fasten.
Old Nov 27, 2018 | 03:09 PM
Tyson's Avatar
what? why would you do that?
where are you getting your info? why do you think any of this is a problem?
AznBlueBoy
Suspension & Brakes
Jul 19, 2011 10:14 AM
Wesman
Suspension & Brakes
Mar 8, 2011 07:58 AM
variable
Oct 20, 2009 08:14 AM
vinuneuro
Suspension & Brakes
May 7, 2007 06:36 PM
