Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
01 civic rear defroster not working
Old Nov 21, 2018 | 04:12 AM
Luke Mitchell's Avatar
Default 01 civic rear defroster not working
I have a 2001 civic ex coupe and a problem I have been facing is the rear window defroster does not work. The switch seems to be good (lights up when pressed) the connections in the back are good I don't know what it is and with it getting cold now I definitely need it. Any help would be appreciated.
Old Nov 22, 2018 | 05:46 AM
NDNV's Avatar
Default Re: 01 civic rear defroster not working
Check the #14 (7.5A) fuse in the Driver's Under-Dash Fuse/Relay Box under the driver's side dash.
If your power mirrors don't work, this is a dead giveaway that fuse is blown as on same circuit.
Check the rear window defroster relay in the Under-Hood Fuse/Relay Box. Location is relay E at the bottom of this link: https://troubleshootmyvehicle.com/ho...-hood-fuse-box
Otherwise, you will have to check for a short, break or poor ground in the circuit. Also could be a bad switch too.
Old Nov 22, 2018 | 05:54 AM
Alright I'll definitely check those out and let you know what it is thanks for the help
beeman 001
Sep 25, 2017 09:40 AM
Randy1121
18
Jan 10, 2014 06:48 PM
ITR.#1446
Jun 16, 2008 09:22 PM
free99
Audio / Security / Video
Mar 6, 2007 12:14 PM
