Auto to manual changeover...can it be done?
Old Nov 20, 2018 | 05:37 PM
Slow&Steady's Avatar
Default Auto to manual changeover...can it be done?
I'm just curious. How much trouble would it be to convert a 2002 auto tranny over to a manual shift?
Old Nov 21, 2018 | 06:51 AM
hondamark35's Avatar
Default Re: Auto to manual changeover...can it be done?
similar to this how-to
5th Gen Auto to Manual
If I already owned an auto, couldn't find a reasonable price on a similar-condition factory-equipped manual car but came across a good deal on a wrecked/parts car then it would worth the trouble.
there are those annoying little parts that would add up in cost if they were to be bought new. Examples:
-flywheel bolts. flexplate bolts are too short so you'll need the flywheel bolts from the manual car.
-clutch hydraulic line and the clips that hold it in place
-the center console and shifter boot. you could just not have one... but you're not 16
-the auto gauge cluster, would probably work fine, but it would bother me to have the "PRNDL" light stack on there...
hope that info is helpful
Old Nov 21, 2018 | 06:57 AM
shipo's Avatar
It depends upon whether the 2002 Accord has an I4 or V6 engine. If the four-banger, probably one to two thousand; if the six-cylinder, then it could be as much as five grand.
Regardless, it will be better, faster, cheaper to simply sell your 2002 Auto and use the proceeds to buy a new 2002 5-Speed (assuming you have a four cylinder, there were no V6 accords of that generation made with manual transmissions).
Old Nov 21, 2018 | 11:59 AM
Thanks guys, that one link looks really informative.
I wish Honda had made a V6 manual during the 1998 to 2002 run.
I guess I'll just keep holding out for a nice manual shift car.
Old Nov 21, 2018 | 12:39 PM
shipo's Avatar
The 7th Gen Accords and their Acura twins the 3rd Gen TLs (built side-by-side on the same assembly line) are both available with V6 engines and a very sweet shifting 6-Speed manual. Other than the obvious trim differences, the Accord has a 3.0 liter engine and an open differential in the tranny case; the TL has a 3.2 liter engine and a mechanical Limited Slip Differential in it's tranny case. If you are patient, you should be able to find one or the other in pretty good shape; the only real show stopper is the 6MT cars typically fetch anywhere from one to three thousand dollars more than an otherwise identical Automatic car.
Old Nov 21, 2018 | 12:51 PM
Ah ha. Well, what years is the 7th Generation Accord? What years for 3rd Generation Acura TL?
Old Nov 21, 2018 | 01:14 PM
shipo's Avatar
  • 7th gen Accord: 2003-2007
  • 3rd gen TL: 2004-2008
Old Nov 21, 2018 | 01:55 PM
shipo's Avatar
Thinking about the above for a moment, I'm not sure all of the 7th Gen Accord model years were available with a V6 and a 6-Speed Manual, but I do know many were. Regarding the TL, the 2004-2006 model years had the 6MT available on the base or NAV model, however, for the 2007-2008 model years, only the TL Type-S (which by definition has NAV) was available with the 6MT.
Old Nov 21, 2018 | 03:49 PM
Stelcom66's Avatar
I can say once you find a 1999-2002 Accord with a manual transmission in good condition you'll likely be very glad you took the time to search. I was very fortunate to find an example last September, a 1999. It's got 169k on it but feels like it has about 60k. I assume you already have a gen 6 Accord - so I probably don't need to mention the other virtues of the cars, like how it still feels solid and well put together. Mine is just fun to drive - that I didn't expect. I was just looking for something that would likely be reliable for the long haul and inexpensive. It's been over 20 years since I've owned a Honda and now see what I've been missing.
ejoner
199
Mar 22, 2022 03:01 PM
ChangT
May 26, 2011 07:16 PM
uenolove
Feb 27, 2008 04:32 PM
acura8851
Jun 2, 2006 01:02 PM
