Accord wont Rev past 4k rpm
Old Nov 18, 2018 | 06:51 PM
Raul Cipriano's Avatar
Default Accord wont Rev past 4k rpm
Hello I just got a 97 accord lx with the f22b2 engine. The car at first didn't rev past 3k rpm and ha a p1361 code.
I bought the sensor and replaced it, the car had the original timing belt ( @277K miles!) so replaced that too.
followed this guide for it: https://honda-tech.com/forums/honda-...f22b1-1908944/
The check engine light is now off and the car revs past 3k rpm but now wont go past 4-4.3k rpm any tips?
i drove the car and looked at the live data when the problem occurs the fuel system changes from closed loop to open loop fault
the spark advance also seems weird to me, when the problem occurs its at 17 and when accelerating its in the 30( idk about the spark advance but it seemed off)
thanks for any help
Update:
Check engine light finally came on and it's a p0172, from what ive read its running lean.
i also have a pending p0170 which is the O2 sensor.
im going to order an ngk o2 from amazon and swap it on saturday hopefully thats the problem
also found this helpful little video
Old Apr 1, 2022 | 10:51 PM
FLYTRAPIN's Avatar
Default Re: Accord wont Rev past 4k rpm
My issue turned out to be the oil pressure switch wasn't compatible with my engine.
TLDR
Car wouldnt rev past 4k rpm while driving. It would bog and jerk way harder than hitting a revlimiter. but still shift once you let up on the accelerator.
tyronej85
Aug 4, 2014 03:31 PM
chechen.DARK
Classic Hondas
Feb 1, 2012 06:27 PM
1993eghatch
Jun 22, 2010 01:54 PM
scooterguy
Nov 26, 2005 08:10 AM
