99 accord 2.3 vtec sohc
Old Nov 18, 2018 | 08:39 AM
Jake Pierson's Avatar
Default 99 accord 2.3 vtec sohc
Showing a random cylinder misfire. Replaced plugs,wires, distributor and rotor . Still showing random cylinder misfire. Ive been told i have a bent valve. But im not a mechanic so i have no idea what to look for or how to find out the problem. Please help
Old Nov 18, 2018 | 09:12 AM
shipo's Avatar
Default Re: 99 accord 2.3 vtec sohc
Have a cylinder leakdown test performed.
Old Nov 19, 2018 | 09:32 AM
FalkenSiR's Avatar
Have you narrowed it down to a cylinder? Try swapping injectors around to see if you can isolate it.
Old Nov 24, 2018 | 01:50 PM
typhoon's Avatar
it could be spark, or it could be fuel.
you could get a "test spark plug" to make sure they are all firing. then You could pull your fuel rail with injectors attached and crank to make sure they are all squirting. If all that's good, it might be a timing problem.
I wouldn't think bent valve first, but if one was bent, you'd have low or no compression. So then I'd do a compression test.
Old Nov 24, 2018 | 07:53 PM
MAD_MIKE's Avatar
MM Gruppe B
Check valve adjustment clearance.
Manual states 90Kmiles, but you would be better off checking every 30Kmiles.
Valves that are too tight, especially the exhaust, will hang open when hot and lose compression.
No compression, no combustion.
No combustion = misfire.
89civichb
11
Mar 10, 2009 08:26 AM
213374U
Mar 10, 2009 06:22 AM
bigdaddyradde
May 12, 2006 07:49 AM
Da1spaz247
Nov 4, 2005 07:57 PM
street dreams
Nov 21, 2004 04:48 PM
