Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
CRAZY dash , headlights and car dies then starts right back up
Old Nov 17, 2018 | 01:34 PM
hondamanwithsam's Avatar
Default CRAZY dash , headlights and car dies then starts right back up
put in new battery , alternator , and new ground off battery. fixed issues for only a day. She turns my headlights on and off , all warning lamps on dash , all gauges drop, car will lose all power then able to jump start it before I stop moving. Checked alternator dv voltage ac voltage ohm reading all my grounds read under 2 ohms , also checked all fuses
Old Nov 19, 2018 | 10:11 AM
thisguyaves's Avatar
Default Re: CRAZY dash , headlights and car dies then starts right back up
Get the battery tested? Also check for a CEL for electronic load detector (ELD)
Old Nov 19, 2018 | 08:11 PM
I had some time yesterday, I pulled the battery out, found that where it had been grounded was to a bracket, pretty much almost directly under the fuse box, it had a bolt lower on the bracket that had wound itself out an the bracket was lose. Also put a 4 gauge wire as engine ground. I also scene an arch spot under the hood. I bungied a isulator over it. Since finding these issues, the car has been back to normal.
Old Nov 22, 2018 | 05:51 AM
NDNV's Avatar
Result: poor battery ground - thanks for posting solution.
Misty Taylor
Aug 28, 2019 11:38 AM
sunshine5882
Jan 18, 2013 01:15 PM
Exdeath
Oct 6, 2010 10:52 PM
ErikDaGenErik
Mar 19, 2007 02:03 PM
ErikDaGenErik
Mar 18, 2007 10:39 PM
