F20b swap ECU question
Old Nov 17, 2018 | 04:04 AM
Roberts71's Avatar
Default F20b swap ECU question
I swapped a. F20B into my 1992 prelude and converted all the stuff from the original h22 onto the motor so it is all obd1. But car still won’t run. I have a p72 ECU with the F20B chip in it. Am I using the right ECU. Or do I need a different one?
Old Nov 17, 2018 | 07:51 AM
TimiK's Avatar
10 Year Member
Default Re: F20b swap ECU question
Basemap might not run it perfectly so you might want get proper tune later
Are you sure that all the sensors work properly? And other wiring are correct
Distributor and oilpump are usdm? And sensors?
B00stedH22A
Aug 26, 2010 04:37 AM
Tip14
Dec 14, 2008 10:14 AM
NO_FEAR_LWO
Aug 22, 2006 05:24 PM
JasonST
Jan 30, 2006 08:04 PM
B1894civic
Apr 6, 2005 11:54 AM
