Transmission & Drivetrain Gearboxes, Differentials, Clutches
Ep3 5 speed final drive swap
Old Nov 16, 2018 | 11:12 AM
DirtAccord's Avatar
Default Ep3 5 speed final drive swap
My dirt track ep3 needs alittle more speed in second gear. It needs to reach 77 in 2nd gear to be hitting rev right before the turn. Currently it will hit 65 and bigger tires won’t increase it enough to help. My plan is to change the 4.764 final drive in the 5 speed to a 4.0-4.2 aftermarket final drive. The internet has them but they seem to all be marketed towards the RSX-S 6 speed. My question is, will an aftermarket final drive for the 6 speed work in my ep3 trans? One marketed towards the ep3 are much more rare.
Old Nov 18, 2018 | 11:29 PM
Aquafina's Avatar
Default Re: Ep3 5 speed final drive swap
Yes. Fitment is the same. The only difference being the clutch housing bearing size, which you can change out. You can contact me via my website (link in signature) to order a Gear-X 4.0 FD and anything else you need for the trans.
DirtAccord
Jan 17, 2019 03:16 PM
DirtAccord
Nov 17, 2018 04:57 PM
StinkyTofu
Jul 14, 2003 07:54 AM
Trey
Jan 23, 2002 05:58 PM
powerfulperformance
Aug 11, 2001 03:08 PM
