Confirming - Automatic transmission cooler self-bleeds?
Old Nov 15, 2018 | 01:02 PM
maraster's Avatar
Default Confirming - Automatic transmission cooler self-bleeds?
Hi All, we are just about done putting back together the cooling system after our radiator blew on our 1994 Accord LX 4dr AT, and just wanted to confirm that the ATF system self-bleeds. Is that correct or am I missing the instructions somewhere for that? Thanks, hope you are all enjoying your hondas!
Old Nov 15, 2018 | 05:51 PM
schreps's Avatar
Default Re: Confirming - Automatic transmission cooler self-bleeds?
No bleeding, the trans pump will fill the cooler if it's hooked up correctly. So no worries the air will be forced out.
Old Nov 16, 2018 | 10:21 AM
FalkenSiR's Avatar
You could fill and drain out a few times if you are worried about coolant in the tranny. An easy way is to just unplug the rad lines and let it pump it out.
Old Nov 17, 2018 | 10:15 AM
maraster's Avatar
Thank you guys for the replies!
heraldo
15
Jul 25, 2013 08:38 PM
Chrys9008
May 19, 2013 10:48 PM
chiaxi2002
Apr 20, 2009 09:31 AM
soon2bdropped
Nov 27, 2006 08:51 PM
whiteboy4life74
Aug 26, 2004 08:07 AM
