Obd1 code 29 for 94 Honda Accord?
Honda Accord dx coupe 1994. When I read my check engine lights after jumping the blue connector below my glovebox I get 2 long flashes and 9 short flashes pause and then repeats. The manual I have doesn’t reference code 29, and I can’t find it on the web anywhere so far. What is OBD1 code 29 trying to tell me?
Here's a really good list but no 29... https://honda-tech.com/forums/honda-...eryone-682412/
Im wondering if the count is incorrect for the first digit, so maybe you have a 19 which is the AT lock up control valve OR there are two codes 2 and 9, O2 sensor and cylinder sensor.
What symptoms does it have ?
I think I figured out obd1 code 29 or 920 for 1994 Honda Accord ... I just replaced external ignition coil and starts every time... when u jump the blue connector and get 9 fast flashes first and 2 slow flashesh after a pause (in that order), it meant ignition coil replacement in my case.
rmiv1985
Jun 27, 2019 04:10 AM
JeffWashington
Dec 12, 2016 10:34 AM
