Vafc or Safc with turbo?
Old Nov 13, 2002 | 05:13 PM
GreenGSR's Avatar
Default Vafc or Safc with turbo?
for those of you with Vafc or Safc: Did you install them yourself and how difficult was it? Which should i use with a turbo? thanks in advance
Old Nov 13, 2002 | 05:47 PM
SlowazzGSR's Avatar
Default Re: Vafc or Safc with turbo? (GreenGSR)
Its a simple question you should ask yourself. Does your car have vtec? I see in your sig that it does so that should answer your ?.
Old Nov 13, 2002 | 06:30 PM
SIK IN DA HED's Avatar
New User
Default Re: Vafc or Safc with turbo? (SlowazzGSR)
do u even know the difference between the two?
Old Nov 13, 2002 | 06:45 PM
B94Cast's Avatar
Default Re: Vafc or Safc with turbo? (dlplayboy)
You can put an V-AFC in a car w/o the vtec portion active... it just never gets a vtec strobe, and has nothing to send it to. However, if you intend on getting vtec, doing a LS/Vtec mod, have a GSR, ITR, etc... then get the V-AFC... otherwise, the two models are identical.
So, IMO, get the V-AFC if vtec will *ever* enter the picture...
Edit - P.S. your sig says GSR... ?
[Modified by B94Cast, 8:48 PM 11/13/2002]
Old Nov 14, 2002 | 07:11 AM
MugenGTR's Avatar
Default Re: Vafc or Safc with turbo? (B94Cast)
if u have vtec get the vafc, if u don't, get the safc. and as for installation they do sell harnasses that u can jus plug in instead of cutting wires.
btw, does anyone know if they make the harness for the Safc? of do u jus use the harnass for the vtec and jus ignore the vtec wires? thanx
Old Nov 14, 2002 | 07:17 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: Vafc or Safc with turbo? (MugenGTR)
I don't think he's asking which one to use, he's asking if anyone used either for a turbo application.
It depends on what kind of fuel management route you want to go with. If you want to be cheap with me, you can use larger injectors, an AFC, and something to retard timing during boost.
If you want to go full standalone, you don't need an AFC, as the aftermarket ECU will control everything.
Traser
Nov 17, 2006 11:30 AM
J-Spec EG
Jun 9, 2004 06:14 AM
B18badboy
May 25, 2004 09:22 PM
turbogsr13z
May 5, 2002 02:18 PM
Homer_Simpson
Sep 26, 2001 10:31 PM
