Suspension & Brakes Theory, alignment, spring rates....
flipping tie rods
Old Nov 12, 2018 | 11:12 PM
singlecam95ej2's Avatar
Default flipping tie rods
on my 1995 civic dx coupe that's lowered about 31/2in to 4ins on 17 rims so my steering geometry is a bit outta wack so as u can imagine ride quality is **** so I wanted to correct the geometry by getting the tie rods to sit more level instead of at a sevear angle and I want to change the way they get mounted to the steering knuckle by copying the 1993 honda accord has its tie rods I wanted to know if it is possible or if its a good idea to mount the tie rods to the steering knuckle with the castle nut pointing up to the skygoing instead of them pointing to the floor the way the accords are setup anyfeed back would be helpful
Old Nov 13, 2018 | 12:24 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: flipping tie rods
Ride quality is **** because you’re on 17s with most likely rubber bands for tires and you’re dropped too low.
Are you banging your UCAs or did you clearance the shock towers?
What suspension setup are you running?
Old Nov 13, 2018 | 03:55 AM
Chrisfrom1986's Avatar
No its a taper fit.
Old Nov 13, 2018 | 07:46 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
I think K tuned? makes a bumpsteer kit with special bolts for the taper. It drops the tie rods down.
But why would that affect ride quality?
Old Nov 13, 2018 | 12:23 PM
Tyson's Avatar
Originally Posted by singlecam95ej2
on my 1995 civic dx coupe that's lowered about 31/2in to 4ins on 17 rims so [blah blah]
i dunno how you logically start off with this and then say your problem is your steering geometry causing your ride to be ****.
crowscare
Dec 17, 2014 05:29 PM
sleeptime
Mar 17, 2011 07:07 PM
Suzukii
Feb 28, 2008 05:46 PM
ek9tl
Suspension & Brakes
Mar 23, 2007 05:27 PM
elpanopticon
Feb 17, 2007 11:00 AM
