IGNITION SWITCH ODDITY??
Old Nov 11, 2018 | 12:00 AM
stella88's Avatar
Default IGNITION SWITCH ODDITY??
DETAILS FIRST, JUST BEGUN MY INVESTIGATION WITH THIS, NO CRANK NO START
BOUGHT THE EG SEDAN 5 SPEED IN SEPTEMBER WITH 279000 MILES
HAVENT DRIVEN IT MUCH, HAS SAT THE MAJORITY OF THE TIME, MOSTLY USED AS A BOOMBOX WHILE I FIX OTHER DUMB ****
i RAN IT FOR A FEW MINUTES HERE AND THERE, HELP KEEP THE BATTERY CHARGED, WHICH IS NEW
NOTICED THAT THE RADIO TURNED OFF AND ON, SO I TRIED TO START THE CAR...NOTHING, SO I CHARGED THE BATTERY, STILL NOTHING
SO FAR IVE CHECKED ALL THE QUICKIE TROUBLE SHOOTING
BATTERY GOOD, NEW IN FACT
FUSES, ALL GOOD
MAIN RELAY CLICKS, HUMS, ALL THAT FUN STUFF
THATS ALL IVE DONE AT THE MOMENT
REASON I SAY ODD:
NO HEADLIGHTS NO POWER WINDOWS NO RADIO
WHEN I TRY TO CRANK THE CAR OVER, DASH LIGHTS GET DIMMER
TRY THE HEADLIGHTS SAME DEAL, BUT WITH NO LIGHTS
D.I.Y. WIRE FROM THE STARTER SOLENOID TO THE IGNITION SWITCH
POSSIBLE FORCED LOCK CYLINDER, ALOT OF SLOP IN THE CYLINDER,
RETURN SPRING "WORKS" BUT THE THE PENDULUM HAS STUCK IN THE OUT POSITION, UNTIL YOU KICK THE KEY BACK
Old Nov 11, 2018 | 02:02 AM
muellersfan's Avatar
Default Re: IGNITION SWITCH ODDITY??
Please don't abuse the caps lock key and also mention the car you have.
Does the fuel pump prime?
Do you see strong spark at all 4 spark plugs?
CEL codes?
Old Nov 11, 2018 | 08:01 AM
mk378's Avatar
Charge battery overnight with an AC powered charger. Running the engine for a few minutes at a time will not keep battery charged if someone keeps running it down playing the radio.
Old Nov 11, 2018 | 11:49 AM
stella88's Avatar
92 civic sedan 5 speed D15B
yes the battery was charged over night
going to check out, spark and fuel right now
Old Nov 15, 2018 | 09:56 PM
stella88's Avatar
f.y.i I replaced the lock cylinder and the ignition switch, sedan fired right up
Pagoda
Sep 15, 2014 09:30 PM
DevilJin6six6
May 25, 2010 06:12 PM
waciii
Feb 14, 2009 01:02 PM
nedjinski
Sep 7, 2007 03:04 PM
Maireeka
Jun 20, 2007 08:11 PM
