Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2001 LX no spark
Old Nov 10, 2018 | 06:14 AM
mark4586529's Avatar
Default 2001 LX no spark
I have power to the coil but Im not getting a signal for spark. Computer says nothings wrong....
My computer with the engine turning over shows everything is good... Im seeing RPMs and spark advance...
Old Nov 10, 2018 | 11:46 AM
thisguyaves's Avatar
Default Re: 2001 LX no spark
Are your spark plugs not sparking? Like, have you taken them out and seeing no spark? Or does it not run, and you've immediately assumed no spark? Replace plugs and engine block ground. If the coils, ground and plugs are good and the ECU sends the signal it sparks, that's all there is to it
Old Nov 11, 2018 | 07:47 AM
I removed one of the coils and stuck a screw driver in it, next to the body with the engine turning over no spark. I I have 2 voltages across the wires, I have with the engine turning over a constant 12v on one and a constant 4.8 on the other.
Old Nov 11, 2018 | 08:19 AM
How close, becaus yu'd need to be very close to make a spark and you probably wouldn't see it. Try a new coil.
Old Nov 11, 2018 | 09:40 AM
Really? 4 new coils? Its not hitting on ANY cylinder.
Old Nov 11, 2018 | 01:07 PM
Sounds like you need to pull the plugs, ground them, and make sure it's not sparking. power to the coil, the coils, the plugs, engine grounds.... could all be the problem.
RichardSiem1
May 22, 2013 01:43 PM
tcyman2718
Feb 28, 2013 09:08 AM
omeezy
Jul 22, 2011 10:57 AM
deca_b16
May 19, 2007 09:52 AM
smallttocs
May 25, 2004 08:39 PM
