having trouble with the t bracket in my ef b swap. B18b1 with Ls cable trans, innovative engine mounts and a 1990-1993 integra t-bracket. But the bracket does not work. Looks like it needs to reach over about 2 inches to fit on the mount. In the picture i undid the mount from the subframe, and attached the mount to the t-bracket which is bolted to the engine.
The red circle is the hole on the subframe the mount should line up with. The green circle is where the bolt hole is on the mount. So it looks like the bracket needs to extend over a couple inches.
Any help is appreciated
I am using the "(EF W/B-Series)" mount in the picture below
92-93 trans is cable as well. Thats what i have, mine is a 92-93 trans. The only difference between 90-91 and 92-93 integra trans is input shaft spline count, (i believe) so they use different clutches. And yes i have the cable trans engine mount kit.
I think only 1994+ integras have a hydro trans, and i know the t-bracket is different. I am using the 1990-1993 integra cable trans t-bracket, matches all the pics i have seen online.
Also i scrolled through your thread for 15 minutes or so and did not find anything.
although, maybe i am an idiot and not lining it up right or something. I will try again later and let you know.
