97 honda accord non vtec code p1297 engine dies
Old Nov 7, 2018 | 10:13 AM
accordcrazy92's Avatar
Default 97 honda accord non vtec code p1297 engine dies
Hello everyone,
I have had an ongoing issue with my 97 Honda Accord. To start with I bought this car used and beat up as neck by the previous owner. Ive fixed many of its issues so far. But when it comes to this code which is Electric Load Detector voltage low im puzzled because there is no information anywhere online. Can someone help me locate the ELD. Also the only way I can start my car is if I connect my OBD scanner so I'm guessing thats a grounding issue. Can anyone help me with all grounding locations under the hood that woukd be resposible for this issue please.
Old Nov 7, 2018 | 02:48 PM
Default Re: 97 honda accord non vtec code p1297 engine dies
So I figured out my issue. I checked ground wire g01 I check ground wire g02 I also checked ground wire g101. G01 was good. G02 was good. However ground wire g101 next to the manifold was good but the plate holding onto the manifold had loose bolts. So I had to retighten the two bolts holding the plate and that solved my issue.
regnevazota
Sep 21, 2022 06:53 AM
Chickenfcker
Dec 27, 2014 07:24 PM
JAmers2004
May 5, 2014 07:22 PM
pk_man
Nov 29, 2013 10:09 AM
fcmoozin
Jun 28, 2012 06:44 PM
