suspension screwy sway bar busheshings upgrade or just fix it?
Old Nov 5, 2018 | 01:10 PM
Donavan Meyers's Avatar
Default suspension screwy sway bar busheshings upgrade or just fix it?
I have a 1997 accord with the f22b auto. I keep getting a clunking sound in the front right when I hit a bump so I looked up the car and it looks like the connecting bar bushings on the sway bar are totally shot. Now I know I could just change the bushings out and stick with the stock setup or I could get an upgrade kit with all the bushing and new sway bar and whatever else comes with it. What would be everyones suggestion, currently the car is bone stock but I want to make it a little better with the handling and some extra power in the engine eventually. If i upgrade to a new heavier sway bar in the front do I need to do the rear at the sway bar? Also im on a pretty tight budget so if you suggest upgrading is there a frugal way to do so without breaking the bank.
PS this is my daily driver im not looking to turn it into track car though I wouldnt mind it handling a bit like it was on rails
Thnks
Old Nov 5, 2018 | 01:28 PM
Free Man's Avatar
5 Year Member
Default Re: suspension screwy sway bar busheshings upgrade or just fix it?
I’d suggest that you stick with stock replacement bushings for now and not touch the sway bar itself. If you enjoy how your car currently rides, then you’ll not like the feel of a big ol beefy sway bar up front. unless lifting one side of your car off the ground every time you hit a pot hole is your idea of fun, which is what will happen with a big bar, stick with a smaller stock one. I have a 92 Integra ls and I run stock sway bars with Neuspeed-Bilstein coil-overs, 15x8 inch wheels w/ stretched 185-55-15 tires and this is enough of a suspension upgrade for me being that my car will never see a track. No need to install race car parts on a street car.
Old Nov 5, 2018 | 01:46 PM
19Accord97's Avatar
I've got a 97 and since you don't have a rear sway bar I am assuming it is a DX or and LX (like mine). I bought the Energy Suspension bushings since they were so cheap ($14 If i remember correctly) and the front and rear sway bars from ST Suspension. The rear bar is easier to install than other brands because you use existing holes and don't need to tap or die new ones. The improvement was night and day difference for the rear but nothing too much for the front. By far, the rear sway bar was the most noticeable difference on my Accord other than lowering it.
But, if it is stock and you are on a budget, just get the bushings for the front and do the sway bars when ST has their one time a year $100 rebate.
CWBETB
Dec 25, 2006 02:12 AM
krazyk
Suspension & Brakes
Apr 12, 2005 01:55 PM
unknown2
Sep 2, 2004 06:29 PM
MaaseyRacer
Aug 17, 2004 09:40 PM
Vinceg99
Jan 10, 2003 10:56 AM
