02 Accord Engine oil
Hi,
I am new to this family.
Mine is a 02 Accord EX Sedan (4 cylinder) with 200k located in Florida.
May I ask which brand and grade of oil should I use?
I have searched the manual and it said 5W-20 is recommended and 5W-30 can also be used.
Do I need special one for a high-miles engine like mine ?
Many thanks.
Many thanks.
Don't over think the brand of oil, oil brands are like religion; use whichever brand you worship. Said another way, regardless of which brand you use, assuming you use the correct grade and keep up with your oil changes, the engine will outlast the rest of the car.
As for grades, I use 0W-20 in both of my high mileage Honda engines, that oil is superior in every respect to 5W-20. Regarding 5W-30 (or better yet, 0W-30), yes, with 200,000 miles on the clock, you certainly won't hurt your engine by going with the heavier oil, you may lose a little fuel economy, but that's about it.
If the car has had synthetic in it so far keep using synthetic, specially at this mileage. As far as viscosity goes (you haven't provided enough information like if it leaks or burns, etc) and everyone and their grandma will have differing opinions. However, All things being equal, I would run 5w-30 regular or synthetic based on my first point. Wether you choose a high mileage blend will depend on other factors (agan you have not provided enough information to make the BEST suggestion) but most of the time I would NOT recommend a high mileage blend unless the engine has been using it for a long time.
Simply because a higher mileage engine has higher internal clearances (out of spec, worn out). A 5w-30 oil will help with this all things being equal. It might increase the pressure slightly also which is not a bad thing at 200k miles. This is why people have traditionally added thicker oils to engines that burn thinner oils as a band aid. There is nothing wrong with doing this. You are proportionally adding the type of lubrication the engine needs as it ages.
Jrocks
Sep 16, 2014 08:32 PM
diyer
Jun 18, 2004 07:44 AM
