suspension techniques sway bars for 96-00 civic?
Old Nov 13, 2002 | 04:22 PM
blkrice's Avatar
Default suspension techniques sway bars for 96-00 civic?
i am going to purchase new sway bars for my 99 ex,suspension techniques sell two kits for the front and one say with original front bar and the other says with out, my question is what is the front bar?
Old Nov 13, 2002 | 04:35 PM
sivik2nr's Avatar
Default Re: suspension techniques sway bars for 96-00 civic? (blkrice)
Rephrase your question. Does not compute.
[Modified by sivik2nr, 7:36 PM 11/13/2002]
Old Nov 13, 2002 | 04:44 PM
blkrice's Avatar
Default Re: suspension techniques sway bars for 96-00 civic? (sivik2nr)
suspension techniques sells the two kits and i dont know which one to buy the two kits say "96-00 civic w/o original front bar",the 2nd kit says 96-00 civic w/original front bar my question is which do i buy?
Old Nov 14, 2002 | 09:56 AM
Mugen Hamster's Avatar
Default stuff
Are you sure it's the front bar? Usually they mean the rear bar. On the Si, there's a stock rear sway bar. This does not come stock on other civic trim levels, such as ex, blah blah. I bought the front and rear bar kit for my 2000 ex and it's pretty good. it will require a little drilling in the rear, because the braces the bar comes with don't match/fit the holes already on the car. It's not that big a deal, and the results are pretty good. if you're gonna buy the kit, get the one with both front and rear bars. it's worth it in the end! plus, this kit isn't all that expensive!
Old Nov 14, 2002 | 10:23 AM
cjames235's Avatar
Default Re: stuff (import_racer_7)
ex has a factory front sway bar so get the kit that says "with stock front bar"
the other kit that is made for cars without a stock front bar is for dx's
i agree with import racer. the kit is cheat, good, and even though you have to drill 2 holes it is very easy to install. by myself it took me 4.5hrs to put on front and back. my advice is definately have someone help you because trying to hold up the bar and bolt it on at the same time is a bitch.
Old Nov 14, 2002 | 11:01 AM
autoEXturbo's Avatar
get the kit with both bars, you will be very pleased. I put the on and damn, the car could take corners like a bitch.
a_benito86
Suspension & Brakes
Sep 19, 2016 07:17 AM
jredhonn
Suspension & Brakes
Dec 26, 2007 05:34 PM
wtfitzsoda
Apr 14, 2006 09:49 AM
blackstar
Sep 27, 2005 02:17 PM
bw54867
Nov 3, 2002 11:39 PM
