What IACV to use on my B20 swapped civic ?
my set up is 00 jdm high comp B20b + 5 spd ls tranny with ls manifold and throttle body chipped p06 . My IACV is going bad. What IACV should I get ? The same one or one for a crv ?
OP, how do you know your IACV is "going bad" ??? What symptom is your engine experiencing that makes you believe this diagnosis ??? If you replace the IACV, you can safely use a IACV from a '96-01 Integra, a '97-01 CRV or a '99-00 Si.
madvilliany13
Dec 17, 2012 06:16 PM
