K swap Subframe question
Old Oct 31, 2018 | 10:58 AM
CarFanatic26's Avatar
Default K swap Subframe question
So I have a 97 EK Hatch, and I am doing a k24 swap. I have purchased a complete integra front subframe. Meaning it has everything, a arms, sway bar, powersteering, etc. Will this bolt directly in and work? Or will I have to swap some components from my ek subframe?
Old Oct 31, 2018 | 12:41 PM
tony_2018's Avatar
Fish Twig
Default Re: K swap Subframe question
Yes, confirmed.
Old Oct 31, 2018 | 12:46 PM
ok awesome so I am going in the right direction!!
Old Oct 31, 2018 | 04:52 PM
Freedo_Civegra's Avatar
Make sure to use the bolts for the Integra subframe.
Old Oct 31, 2018 | 05:33 PM
Yes. I have to order those from Acura. You by chance know the part number?
Old Oct 31, 2018 | 06:46 PM
I don’t have them; but you should be able to get them either from an Acura parts website/dealer for a 94-01 Integra, or from a Honda parts website/dealer for a 92-95 Civic.
Old Nov 1, 2018 | 06:01 AM
is it 4 bolts per side?
Old Nov 1, 2018 | 06:20 AM
If you get the EKK1 mounts, you don’t have to swap the subframe do you?
EDIT: you only need these 3 on each side:
90161-s04-000
90162-sr3-000
90167-sr3-000
Old Nov 1, 2018 | 06:49 AM
I"m doing the EKK2 mounts
Old Nov 1, 2018 | 06:52 AM
90161-s04-000
90162-sr3-000
90167-sr3-000
awesome ok thanks man! I will order these.
I assume its easy to know which one goes where?
Old Nov 1, 2018 | 09:40 AM
#19 = 90161-s04-000 = M14x100
#20 = 90162-sr3-000 = M14x60
#23 = 90167-sr3-000 = M14x120
Also so note that you must use lower control arms from either a 92-95 Civic or a 94-01 Integra.
Old Nov 1, 2018 | 09:55 AM
In this picture of 94 Integra it shows 4?? I’m confused.
Old Nov 1, 2018 | 09:58 AM
Sorry, my pic is for a 95 Civic.
Whats the part number and bolt dimensions for #28 in that pic? I bet it’s for the lower control arm.
Old Nov 1, 2018 | 10:08 AM
it just says this
Bolt, Flange (14X35) - Acura (90168-SR3-000)
Old Nov 1, 2018 | 10:47 AM
it just says this
That definitely is one of the bolts for the lower control arm. You might can reuse your EK bolts for it.
Old Nov 1, 2018 | 11:07 AM
ok so I just need 3 on each side then. thank you so much!!!
Old Nov 1, 2018 | 11:45 AM
Yep, #20, #21, & #26 according to the Acura diagram.
Post some pics of your build!
Old Nov 1, 2018 | 11:52 AM
I will! just gathering parts at this point!
musasabi
Nov 13, 2008 12:29 PM
ekhonda
Apr 16, 2007 07:25 PM
kiyoshikun
Jun 11, 2006 10:11 AM
rtsol
Nov 13, 2004 06:37 AM
