Gas leak
Old Oct 28, 2018 | 11:04 PM
Dr Dale's Avatar
Default Gas leak
My 98 Accord started leaking fuel. I noticed it after I had gotten gas and the next day there was a puddle underneath the car.. I jacked it up and noticed it was dripping off the front of the tank. I don't wanna drop the subframe to replace the tank so if any one has any tips or tricks please let me know it has 277k on it but runs just fine.
Old Nov 15, 2018 | 05:56 AM
schreps's Avatar
Default Re: Gas leak
Remove the fuel pump access cover, its located in the trunk and have a look at the fuel line connectors and the tank to pump gasket. The vent valve cant be seen through the pump access but if its leaking maybe fuel has run down into the pump area.
Old Nov 15, 2018 | 06:12 AM
schreps's Avatar
vent valve is item 11, pump is item 1
the filler neck hose 17, could be leaking such that the fuel is running around the tank lip and dripping off the front.
slvrslepr
Aug 20, 2008 06:07 PM
jerry454
Apr 21, 2008 10:35 PM
gsrswapdcivic
Apr 13, 2005 07:01 PM
kaoss_11
11
Dec 9, 2004 08:29 PM
digitalspice
Oct 2, 2001 02:29 PM
