Transmission & Drivetrain Gearboxes, Differentials, Clutches
HELP!! CLUTCH ISSUES.
Old Oct 26, 2018 | 03:35 PM
Notahondatech's Avatar
Default HELP!! CLUTCH ISSUES.
I just replaced the bad leaking master clutch cylinder on my 1995 Honda Civic. When i replaced made sure all fittings were tight. I loosened the bleeder valve and had a helper pump the pedal the same way I would bleed brakes(down then open. Up while closed. Down and open.) I probably did this for 40 minutes. A whole bottle of brake fluid and still getting air out of bleeder valve. I know how to bleed it but it seems I'm pulling air from somewhere. Please help. Thanks.
Old Oct 26, 2018 | 07:34 PM
MastaFlyMason's Avatar
Default Re: HELP!! CLUTCH ISSUES.
Slave cyl? I usually replace both at once
Old Oct 27, 2018 | 07:31 AM
The slave is good as far as I can tell. The air is not leaving the system. Could it possibly be a faulty master even though it is brand new?
hitop
Aug 13, 2015 10:34 AM
Valenciabrihh
Dec 29, 2014 05:25 PM
tlovaj
Dec 18, 2008 02:44 PM
autoxthis
Aug 21, 2008 08:56 PM
r1de4life
Jan 16, 2006 10:06 AM
