Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Key Stuck, P and D Lights
Old Oct 21, 2018 | 11:37 AM
tlerp's Avatar
Icon5 Key Stuck, P and D Lights
About a month ago I purchased a 2002 Honda Civic from a used car lot for dirt cheap. Upon purchase, I was informed that it had a new transmission, but have no proof of that whatsoever. It does feel newer than the mileage suggests, as I near 193,000 miles.
The transmission, from what I have noticed, doesn't have any major problems.
Although, I do have a problem that I'm unsure if it ties to the transmission.
About 50% of the time that I go to put my car into park, the P light comes on as usual, and I try to remove my key, but am unable to. When I turn the car back on, the lights that show are Park AND Drive at the same time, never any others. This stays on for about 3 seconds before a click sound happens and then the Park light is left on, but the key is still not removable, and the lights return when turning it on again. It is after that I put the car into drive without the motor running and let off the brake for a moment that I can put it back in Park and take the key out... most of the time (sometimes it takes me a few tries at this before it works).
I've seen similar posts with different lights, like Park and Neutral, but none of those have true answers as to what's wrong. I did bring this issue up at a mechanic but they said it was probably because of the new transmission and shrugged it off as if it wasn't a big deal.
Old Oct 21, 2018 | 05:31 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Key Stuck, P and D Lights
Issue may be due to a faulty transmission range switch (located on the transmission). Transmission range switch can be tested.
Old Oct 22, 2018 | 09:26 AM
NDNV's Avatar
Or perhaps that the donor transmission was not the same version as the original.
Old Oct 22, 2018 | 09:30 AM
tlerp's Avatar
I had that idea but there’s really no easy way to fix that in this case that I’d know of.
teetstyshon
Jul 8, 2013 11:57 AM
milo-gsr
Oct 28, 2009 03:41 PM
thirteen_20
Feb 15, 2008 04:33 PM
xjohnny817x
Aug 29, 2007 12:47 AM
USMCAccord
Aug 13, 2005 07:11 AM
