No start unless accelerator pressed wide open
02 Accord SE, 160K. Running great, then no start. Checked/verified basics; battery, spark, fuel pump, injector -both power/signal voltage - all good. No codes showing. Then just gave a try, pushed accelerator to floor and cranked - started up - ran at about 2000 rpm. Once foot off gas, stalls out. Is this sounding like the Idle Air control system? Can it be cleaned up as suggested in some forums- to verify as problem?
What happens when the engine is warm?
You can try to verify. remove the intake duct between the air filter and throttle body. try to start in this configuration (may be a clogged air filter or air filter box inlet). If it does the same thing then find the IACV hole in the inlet area of the throttle body, with your finger covering the hole and throttle closed, have a friend try to start it. Did you feel a vacuum pulling your finger? If no, the valve is probably stuck shut. Check all the connectors, vacuum lines, the pcv and egr if hasn't been recently cleaned. I guess this could be a fuel pressure regulator, did you measure the rail pressure?
If you clean the IACV be careful not to get TB cleaner in the motor.
just my 0.02
just my 0.02
just my 0.02
just my 0.02
bustedTaiLight
Mar 28, 2016 03:32 AM
wanderinglost
Sep 26, 2008 05:57 AM
GarageAlchemist
13
Oct 1, 2006 03:40 PM
