Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Are my winter tire rims unsafe? Pics inside
Old Oct 15, 2018 | 04:37 PM
TOPDAWG's Avatar
Default Are my winter tire rims unsafe? Pics inside
As you can see my rims are not flesh on the hub. the guy pitting my tires on said this can make you have issues and is not safe. I just wanted to get someone else's option on the matter. I've no issue getting new rims if I need too.
Old Jan 23, 2019 | 05:53 PM
92hondaex4door's Avatar
Default Re: Are my winter tire rims unsafe? Pics inside
I have the same situation with my 2006 Civic. Bought some steelies for winter off another make and model car. U can get hub rings to take up this gap if it bothers you. My fiance runs this setup 100 miles a day for 2 winter's with no problems. Mark sure lugnuts are seated and torqued.
Old Jan 23, 2019 | 10:08 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
There is nothing unsafe about a non-hub centric wheel... in fact, most aftermarket aluminum wheels are not hub centric directly... they rely on the use of a hub centric ring to take up the gap. At worst, you may get some wheel/tire vibration unless your wheel balance is really good.
Old Jan 24, 2019 | 05:27 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
To help reduce vibration when the hub ring is not present, you can torque all the lug nuts with the wheel off the ground. This helps the lugs center the wheel forcing a lug centric method of centering the wheel.
hundo
Honda Civic (2001 - 2005)
10
Mar 11, 2008 11:46 PM
hundo
Mar 11, 2008 02:31 PM
VIS250P
Dec 3, 2005 06:08 PM
DIY_Racing
Honda Motorcycles
Mar 9, 2004 12:09 AM
