TypeR suspension conversion
Old Nov 13, 2002 | 02:33 PM
Fuuma0083's Avatar
Default TypeR suspension conversion
I was wonder what i need to convert my suspension (GS-R) into a TypeR???
*The struts (shocks) i want, only fits TypeR sus.*
[Modified by Fuuma0083, 6:38 PM 11/13/2002]
Old Nov 13, 2002 | 02:34 PM
Regular Series's Avatar
Default Re: TypeR suspension conversion (Fuuma0083)
Hm, I'd think that it could be done - I'd always assumed that the R had the same chassis as other Integras...
Old Nov 13, 2002 | 02:56 PM
emr88's Avatar
The rear shocks and lower control arms on ITR's are different, so are all the bushings. To get ITR shocks to fit, you would need ITR LCA's. They are ~$100 for a pair.
Front sway bar is the same (at least GSR/ITR, LS may be different). Rear swaybar on ITR is 22mm while GSR is 13mm. To get a ITR rear swaybar to fit, you'll need a reinforcement bracket (or washers) info can be found here
http://www.geocities.com/bretq/mounting_kit.html
or
http://www.beaksproducts.com/products.html
Old Nov 13, 2002 | 06:09 PM
Fuuma0083's Avatar
Default Re: TypeR suspension conversion (emr88)
or
I have the 22mm rear swaybars
So your saying i just need the ITR LCA for typeR suspension to fit.
*Is this a simple unbolt and bolt replacement*
(as in no cutting or major modifying?)
Old Nov 13, 2002 | 07:29 PM
emr88's Avatar
Yeah, all you need is the ITR LCA's, they bolt right in. One thing I don't know is if the new LCA's already come with the bushings in them or if you need to purchase them separately.
superseign
Jul 16, 2013 09:20 PM
I got a honda
Jan 8, 2005 10:10 AM
cyrk007
Oct 11, 2003 06:23 AM
Shark Tank
Feb 16, 2003 05:06 PM
Dorikamu
Sep 5, 2002 06:27 PM
